Bringing up an Interface
Feb 1st, 2007
This is Zeeshan. I Have a pix firewall 525 and its IOS version is 6.3(3). Actually both my interfaces ethernet 0 and ethernet 1 are administratively shutdown and now I want to bring up both these interfaces......I have tried so in the configuration mode by using the command "no interface ethernet1 auto shutdown" according to the help available on the IOS, but after i press "Enter" it shows me the command for help and the command does not executes....so, does any body have some idea about this? that how to "no shutdown" an interface on PIX 525??
Jon Marshall Thu, 02/01/2007 - 07:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Zeeshan
Try "interface ethernet1 auto".
That should bring it up. It assumes you want to set interface to auto-negotiate.
Jon
zeeshan.bokhari Thu, 02/01/2007 - 08:03
Hi Jon,
Thanx for the assistance, but when i entered "interface ethernet1 auto" it came up with "Type help or "?" for a list of available commands".....the command had something missing.....also its not only auto negotiation that i want to enable but also i want to bring up the interface
acomiskey Thu, 02/01/2007 - 08:17
  • Green, 3000 points or more
You must not be in config t.
zeeshan.bokhari Thu, 02/01/2007 - 23:56
Hi Adam Comiskey,
Ofcoarse im working in "config t" mode. its not about the mode I believe.
talisman1310 Fri, 02/02/2007 - 01:37
You can try the below command
interface ethernet0 100full
interface ethernet1 100full
This will force the interface to 100 mbps and full duplex.
