On Cisco 2600 can I limit ISDN callin to one-concurrent-call per username?
Feb 1st, 2007
I have a router C2600 with a BRI line.
I have configured the router to receive call from BRI and assing an access in ppp (releasing an ip).
If on the same BRI I receive a second callin with the same username (i.e. a second caller-ISDN-modem-PC with the same username/password of the first) the router release the SAME IP ADDRESS because affect the same dialer configuration.
In this situation (two users with the same IP) all the comunications doesn't work.
If there is the facility to limit concurrents connections from the same user, I can avoid this situation.
If thi is not possible, how can I avoid the release of the same address to the second user with the same address of the first alredy connected?
Here is my configuration:
username AccountRemote password PasswordRemote
ip dhcp excluded-address 10.8.0.1 10.8.0.200
ip dhcp pool RasPool
network 10.8.0.0 255.255.255.0
default-router 10.8.0.127
ip dhcp-server 10.8.0.127
interface Ethernet0/0
ip address 10.8.0.127 255.255.255.0
ip nat inside
interface BRI0/0
no ip address
dialer pool-member 1
isdn switch-type basic-net3
interface Dialer1
ip unnumbered Ethernet0/0
ip nat inside
encapsulation ppp
dialer remote-name AccountRemote
dialer pool 1
dialer-group 1
peer default ip address dhcp
ppp authentication chap
Thanks, Roberto
