Need win 98 drivers for AIR-CB21AG card , any hope?
Feb 1st, 2007
All,
Take a moment and laugh, but I need to see if I can get a driver for a Toshiba Satellite 2545XCDT with a AIR-CB21AG-A-K9 card.
If anyone has any ideas where I might be able to find such a thing, please let me know. The other option is to install W2k on the box, but I think the CPU is to slow to support the install.
Any suggestions are welcome.
~r
rob.huffman Thu, 02/01/2007 - 13:25
Hi Ray,
No worries :) I still have an older (should be retired, but its hard to throw away an old friend) laptop with windows 98 on it as well. You are out of luck with trying to find a driver for the AIR-CB21AG-A-K9 card. As you have discovered there are only drivers for XP and 2000.
Maybe you could source an old 350 client card (Google $35 - $75 US). There are still drivers available for it (software download);
Cisco Aironet 350 Series Client Adapters
Support of popular operating systems-Windows 95, Windows 98/98SE, Windows 2000, Windows ME, Windows NT, Windows XP, Mac OS 9.X, MAC OS X, Windows CE, Linux and MS-DOS.
Hope this helps!
Rob
justpushplay Thu, 02/01/2007 - 15:22
Rob,
Thanks for your input... The laptop supports both cards and I have an AIR-PCM352. But looking for drivers leads to the same path. XP/2000. Even the legacy stuff is seemingly void of drivers fro these cards. Am I missing something?
Please lead the way. I could use a hand!
~r
justpushplay Fri, 02/02/2007 - 08:29
Rob,
Not sure why I couldn't find that to begin with, but after doing some more diggin I came up. Thanks....
So lets see what happens tonight!
I have my doubts that this will work. It was good to see that the laptop supports both cards. I had no idea.
Somehow I think the Cisco s/w will want more info to make this fly than I have to offer.
I was also poking about for utility that will scan the horizon for a rouge signal...
This seem to fall back towards W2k/xp only.
Thanks for keeping me going. I had given up!
~Ray
