RDP over VPN
Answered Question
Feb 1st, 2007
I've been trying for a couple of weeks to establish remote desktop over a vpn with no success. I am able to establish a connection to the vpn but once connected, I am unable to connect by remote desktop.
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 101 permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.0
ip address inside 10.1.1.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm drop
ip local pool ippool 10.1.1.3-10.1.1.254
pdm location 10.1.1.32 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 10.1.1.32 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 10.1.1.32 c:\cisco
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn address-pool ippool
vpngroup vpn dns-server 10.1.1.2
vpngroup vpn wins-server 10.1.1.2
vpngroup vpn split-tunnel 1021
vpngroup vpn idle-time 1800
vpngroup vpn password ****
telnet 10.1.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
management-access inside
console timeout 0
dhcpd auto_config outside
terminal width 80
Correct Answer by Daniel Voicu about 9 years 7 months ago
It could work if you change the users subnet:
no ip local pool ippool 10.1.1.3-10.1.1.254
ip local pool ippool 10.1.3.3-10.1.3.254
access-list nonat permit ip 10.1.1.0 255.255.255.0 10.1.3.0 255.255.255.0
access-list nonat permit ip 10.1.3.0 255.255.255.0 10.1.1.0 255.255.255.0
nat (inside) 0 access-list nonat
Please rate if this helped.
Daniel
Overall Rating: 5 (2 ratings)
Correct Answer
Daniel Voicu Sun, 02/04/2007 - 23:16
Daniel
