pix vpn tunnel + nat
Answered Question
Feb 1st, 2007
i have been trying to work out this problem since more then two weeks now, but all my efforts are going in vain.
we 've a vpn tunnel established with our partner and working perfectly, now we 've been asked for the following
1. this partner will connect to our network through this vpn tunnel
2. onces inside our network they will connect to our other partner using our network, who is directly connected to us,
although the second partner router which is inside our premises is only allowing few IP's from our internal network.
3. since due to security we connects to first partner using pre-defined Private Range IP Addresses ( i mean we do nat on
our pix from internal IP Addresses to this pre-defined ip addresses) e.g. our network 192.168.1.0 255.255.255.0
and pre-defined VPN Natted IP Address we use 10.10.60.0-25 netmask 255.255.255.0
4. This time "they" will try to establish a connection on IP Address 10.10.60.20 through our firewall to second partner
as following
1st partner server ----- pix ---- internal router ----- 2nd partner router ----- 2nd partner server (different subnet) 172.16.10.2
5. At this point in our pix we 've to change IP Addresses like following to make sure that first partner connects to second
partner transparently meaning to second partner it will look like the traffic is coming from us instead of any other.
172.18.20.21(1st partner source IP) ------------- 192.168.1.200(our internal LAN IP, known to 2nd partner router to allow traffic
10.10.60.20 (1st partner destination IP) ---------- 172.16.10.2 (2nd partner server ip, actually destination for 1st partner)
for all above mentioned case i 've tried do the following on pix but apperantly like i said all went in vain.
1. global (outside) 50 10.10.60.20
nat (inside) 50 172.16.10.2
2. static (inside,outside) 10.10.60.20 192.168.1.200 netmask 255.255.255.255
access-list VPN-PartnerOne permit ip host 10.10.60.20 host 172.18.20.21
Now i am trying this
nat (outside) 1 10.10.60.20 255.255.255.0 outside
global (inside) 1 192.168.1.200
route inside 172.16.10.0 255.255.255.255 192.168.1.100 (our internal router)
this statement will tell our pix that 172.16.10.0 is trusted network and will now where to route packets
Correct Answer by Jon Marshall about 9 years 7 months ago
You need to take care of two routing issues:
Your pix needs to be able to route to 172.16.10.2. It looks like you have this correct in your post.
Your internal router needs to know that 192.168.1.200 (which is the Natted partner 1 ip address ) is to be routed back to the pix.
That should do it
Jon
Overall Rating: 5 (2 ratings)
zulqurnain Thu, 02/01/2007 - 12:54
hello,
little guidance and help from you experts would really great.
acomiskey Thu, 02/01/2007 - 13:02
So, if I understand correctly, you are attempting to make Partner 1 appear as if it is on your inside network 192.168.1.0. Is this correct? Why doesn't partner 2 just allow their subnet?
zulqurnain Thu, 02/01/2007 - 13:13
hello,
Yes, that's correct.
Due to security issue's partner 2 does not want to do that and also other implications with management. therefore, this is the best possible solution we have to make.
zulqurnain Thu, 02/01/2007 - 20:44
hello,
shading a little light on the case would be really helpfull
zulqurnain Fri, 02/02/2007 - 02:23
hello,
i don't believe this, no replies from any person. atleast one can say it's not possible.
Jon Marshall Fri, 02/02/2007 - 10:11
To translate first partners ip address in your above example
static (outside,inside) 192.168.1.200 172.18.20.21 netmask 255.255.255.255
You need to make sure that 192.168.1.200 will be routed back to your pix when traffic returns from the 2nd partner to the first partner.
for the server translation
static (inside,outside) 10.10.60.20 172.16.10.2 netmask 255.255.255.255
Yes you will need the route on the pix for the 172.16.10.0/24 network.
your crypto access-list VPN-PartnerOne is correct.
Jon
zulqurnain Fri, 02/02/2007 - 10:59
hello jon,
thanks alot for the reply. as for the route i believe what i wrote is also correct ofcourse otherwise i will work it out, but i though i should take the advice
Correct Answer
Jon Marshall Fri, 02/02/2007 - 13:23
That should do it
Jon
zulqurnain Sat, 02/03/2007 - 01:11
hello,
i tried your steps, but i guess something is still not right, as in my syslog from pix i am receving this messages. *log is attached
i configured like below
access-list Partner_One permit ip host 10.10.60.20 host 172.18.20.21
route inside 172.16.10.0 255.255.255.255 172.20.4.100
as you we will see in the log that after a while i get SYN_TIMEOUT message appearing. can't understand why?
Jon Marshall Sat, 02/03/2007 - 08:21
I thought 192.168.1.100 was your internal router. Does the pix know how to get to 172.20.4.100 ?
Unfortunately i don't have excel on this laptop so i will look on Monday at work.
What you can do is on the inside interface of your pix
debug packet inside dst 172.16.10.2
debug packet inside src 172.16.10.2
This will show you whether everything is flowing through the pix and into your internal network.
Jon
zulqurnain Sat, 02/03/2007 - 20:26
hello jon,
actually i made a silly mistake, i.e. while writing the config on the notepad just before copy pasting on to the pix telnet, by mistake i wrote 192.168.11.100. but later while examining the config i found my own dumb mistake. anyways, it worked after i changed it to what it should 've been.
Thanks alot for your help & support.
