Ciscoworks with VPN's and PIX's
Feb 1st, 2007
I have a customer that has Ciscoworks installed. (Current modules installed are RME, Cisco View, Device Fault Manager, Common Services, Campus Manager)
Can the customer do config pushes to the VPN and PIX devices using what they have installed or do they need something else added to Ciscoworks to do this? Thanks
Overall Rating: 5 (3 ratings)
kyawzawhtut Thu, 02/01/2007 - 19:03
What you need is CiscoWorks VMS (VPN Management Solution) to manage security devices.
I don't think you can do it with CiscoWorks LMS as it is purely for Routers/Switches.
Cheers.
David Stanford Thu, 02/01/2007 - 19:16
VMS (now CSM) does have additional feature to manage security devices, but RME does have config management capabilities for PIX and VPN devices.
kyawzawhtut Thu, 02/01/2007 - 19:41
thanks for your highlight. I didn't aware that RME support those devices.
Cheers!
lfrancisci Fri, 02/02/2007 - 06:57
How would I use RME to do this with the PIx's and vpn's? Thanks
