Rate-limit burst- 3750
Feb 1st, 2007
I want to rate-limit a vlan to 200Mbps on a 1Gbps link. All traffic above the 200Mbps should be dropped. I have questions about the burst rates:
1) Are the burst rates (normal and max) optional parameters ?
2) If not, how can they be stated to most strictly enforce the 200mbps limit ?
The equation I've been advised to use for "normal" configuration is:
burst= rate/8 * 1.5
maxburst= burst*2
This equation doesn't seem right for limiting to a strict 200Mbps.
Any good links or ideas would be appreciated.
Overall Rating: 5 (1 ratings)
boblutton Thu, 02/01/2007 - 11:41
Does anyone know any good links for understanding the burst vs. the rate-limit
HansPauly Thu, 02/01/2007 - 13:20
If I read you correctly, you want a hard ceiling at 200M period. Without a burst headdomm..
rate-limit output 200000000 0 0 conform-action transmit exceed-action drop
Not sure If I'd do that... but.
boblutton Mon, 02/05/2007 - 08:16
Hans-
Thanks for the reply...yes, I want a hard ceiling at 200Mbps...why would you hesitate to do that ? Perhaps I misunderstand the burst rate and how it should be used...but have found no clear explanation of how to apply this parameter correctly...do you have any suggestions, links ?
On a seperate note, I have found no cisco documentation on "rate-limit" command for the 3750, and have begun to wonder if the command is even supported...I know the "rate-limit" command was supported on older switches...What's strange is that the OS is actually accepting the command and seems to be partially working...
I'm running following IOS
WS-C3750G-24TS, 12.2(25)SEB4,C3750-IPSERVICES-M
Originally I thought that the burst-rate was causing a problem, allowing more data than the rate limit, but now I'm wondering if the rate-limit command is doing anything at all
Any thoughts ?
Bob
wswei2013 Fri, 09/13/2013 - 04:56
Hi ,Boblutton,
just search the topic about CAR, hope this still help other on 2013 futher.haha....
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpolsh.html
Recommended Burst Values
Cisco recommends the following values for the normal and extended burst parameters:
normal burst = configured rate * (1 byte)/(8 bits) * 1.5 seconds
extended burst = 2 * normal burst
And other more info. in the link.
