VLAN range
franklaszlo Thu, 02/01/2007 - 11:08
I suppose both switchs reside in the same VTP domain. If the switch in question is a vtp client, then you must define the vlan on the server. In transparent mode you can define a vlan, but it will only work on that switch.
Which version of VTP do you use anyway ?
