CSS 11500 - Change name device
Feb 1st, 2007
I need to change the device name (hostname) of my CSS 11500. How I can do that? I'm searching since some hours without result.
joebenz Thu, 02/01/2007 - 10:49
the command is "prompt ". You will have to reset it if you reboot the CSS though.
Gilles Dufour Mon, 02/05/2007 - 06:48
to avoid having to retype the name after each reboot, you have to do a save_profile.
Gilles.
