Outbound Fax via AS5850
Feb 1st, 2007
We have built a SIP based IVR application that also sends faxes via t.38. We are getting about a 45% success rate. We also can not train at v.17 only at a slower speed. I have my input gain and output attenuation set to be -3 +3 repectively. I thought maybe the levels were to low to get a good fax transmition. Am I all wet or should I give that a try. Below are my fax setting. Any help would be appreciated.
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
voice-port 0/0:D
input gain -3
output attenuation 3
voicecap configure minERL
echo-cancel coverage 32
no vad
playout-delay nominal 100
playout-delay mode fixed
no comfort-noise
bearer-cap Speech
dial-peer voice 204451 voip
corlist incoming FROM-DEV
answer-address 5557654321
dtmf-relay rtp-nte
codec g711ulaw
fax rate 14400
no vad
