cisco pix vpn to cyberguard vpn
Feb 1st, 2007
I have a site to site tunnel but can't get it to the QM_idle status. Keeps erroring with OAK_ADDR. What does this mean? I think I am not negogiating the ipsec correctly?
Daniel Voicu Sun, 02/04/2007 - 02:49
Hi, something is not configured properly.
Can you post your config?
Daniel
kmgonzalez Mon, 02/05/2007 - 10:15
Can I start with my edit statements? Not too comfortable with submitting whole config.
access-list XXXX permit ip 172.17.40.112 255.255.255.240 172.17.1.0 255.255.255.0
static (inside,outside) 172.17.40.114 172.20.80.230
static (inside,outside) 172.17.40.115 172.20.80.232
static (inside,outside) 172.17.40.116 172.20.80.234
crypto ipsec transform-set transset esp-3des esp-sha-hmac
crypto map vpnpacs 17 ipsec-isakmp
crypto map vpnpacs 17 match address XXXX
crypto map vpnpacs 17 set peer 69.238.9.XX
crypto map vpnpacs 17 set transform-set transset
isakmp key ********** address 69.238.9.XX
isakmp identity address
isakmp keepalive 10
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
ggilbert Mon, 02/05/2007 - 13:06
Configuration seems to be ok. Except, I do not see the crypto map applied to any interface, unless you forgot to paste it.
deb cry isa
deb cry ipsec
Can you run those two debugs and put them in the forum.
Gilbert
kmgonzalez Tue, 02/06/2007 - 06:08
I have this statement that I did not paste is this what you are looking for?
crypto map vpnpacs interface outside
Will run the debugs as well...
kmgonzalez Tue, 02/06/2007 - 08:43
here is the output from the debugs: need to send separately.
deb cry isa:
VPN Peer: ISAKMP: Added new peer: ip:69.238.9.15/500 Total VPN Peers:8
VPN Peer: ISAKMP: Peer ip:69.238.9.15/500 Ref cnt incremented to:1 Total VPN Peers:8
crypto_isakmp_process_block:src:69.238.9.15, dest:outside_int spt:500 dpt:500
OAK_QM exchange
ISAKMP (0:0): Need config/address
ISAKMP (0:0): initiating peer config to 69.238.9.15. ID = 1630960744 (0x61367c68)
return status is IKMP_NO_ERROR
ISAKMP: phase 2 packet is a duplicate of a previous packet
ISAKMP: resending last response
ISAKMP (0): retransmitting Config Mode Request...
ISAKMP (0): deleting SA: src 69.238.9.15, dst outside_int
ISADB: reaper checking SA 0x35955fc, conn_id = 0
ISADB: reaper checking SA 0x2eccb6c, conn_id = 0
ISADB: reaper checking SA 0x3584834, conn_id = 0 DELETE IT!
VPN Peer: ISAKMP: Peer ip:69.238.9.15/500 Ref cnt decremented to:0 Total VPN Peers:8
VPN Peer: ISAKMP: Deleted peer: ip:69.238.9.15/500 Total VPN peers:7
ISADB: reaper checking SA 0x3593ac4, conn_id = 0
ISADB: reaper checking SA 0x364175c, conn_id = 0
ISADB: reaper checking SA 0x3595d84, conn_id = 0
ISADB: reaper checking SA 0x358f574, conn_id = 0
ISADB: reaper checking SA 0x3571d5c, conn_id = 0
ISADB: reaper checking SA 0x35724e4, conn_id = 0
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 0 against priority 10 policy
ISAKMP: life type in seconds
ISAKMP: life duration (basic) of 7200
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: auth pre-share
ISAKMP: default group 2
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0:0): vendor ID is NAT-T
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): SA has been authenticated
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
kmgonzalez Tue, 02/06/2007 - 08:45
here is the deb cry ipsec:
deb cry ipsec:
IPSEC(key_engine): got a queue event...
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with 69.238.9.15
IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) dest= 208.51.30.231, src= outside_int,
dest_proxy= 172.20.80.154/255.255.255.255/0/0 (type=1),
src_proxy= 150.2.0.0/255.255.0.0/0/0 (type=4),
protocol= ESP, transform= esp-3des esp-sha-hmac ,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x4
IPSEC(spi_response): getting spi 0x780d8cac(2014153900) for SA
from 208.51.30.231 to outside_int for prot 3
IPSEC(initialize_sas): ,
(key eng. msg.) dest= outside_int, src= 208.51.30.231,
dest_proxy= 172.20.80.154/0.0.0.0/0/0 (type=1),
lifedur= 3600s and 4608000kb,
spi= 0x780d8cac(2014153900), conn_id= 19, keysize= 0, flags= 0x4
(key eng. msg.) src= outside_int, dest= 208.51.30.231,
src_proxy= 172.20.80.154/0.0.0.0/0/0 (type=1),
dest_proxy= 150.2.0.0/255.255.0.0/0/0 (type=4),
spi= 0x3fbb025b(1069220443), conn_id= 20, keysize= 0, flags= 0x4
IPSEC(add_sa): peer asks for new SAs -- expire current in 30 sec.,
(sa) sa_dest= outside_int, sa_prot= 50,
sa_spi= 0x469d655(74045013),
sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 4,
(identity) local= outside_int, remote= 208.51.30.231,
local_proxy= 172.20.80.154/255.255.255.255/0/0 (type=1),
remote_proxy= 150.2.0.0/255.255.0.0/0/0 (type=4)
(sa) sa_dest= 208.51.30.231, sa_prot= 50,
sa_spi= 0xd6062d29(3590729001),
sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 3,
