intervlan communication on FWSM
aksher
Whcih command is used to enable intervlan comm. in FWSM?
gagansethi
I don't think this is possible with FWSM. you might want to have two interfces with same seurity level talking to each other. though intervlan routing may not be an option with firewall else the firewall functionality might not be used.
you can enable interfaces on the same security level to communicate with each other using "FWSM(config)# same-security-traffic permit inter-interface"
gagan
aryan1980
hi aksher,
try this...
static (HSV,LSV)LSV IP HSV IP nemask X.X.X.X.
u might be knowing this
HSV - high secure vlan
LSV - low secure vlan
all the best.it should work
