Unity UM 4.2 Exchange Calling Name Issue
Feb 1st, 2007
Can someone help me with a question? With Unity 4.2 the subject line has changed to be "message from unidentified caller (XXX-XXX-XXXX)". I've changed the subject line with no problem. But customer is asking why the calling name isn't displayed in the subject line. If it is an internal caller, it works fine. Can some tell me where I can go to fix this issue or tell me that it can't be done and give me an idea why. Look at call viewer in Unity it only shows the number and not the name.
Erick Bergquist Thu, 02/01/2007 - 15:57
Unity does not get the name from call manager, just the number. On external calls from non-unity subscribers it uses the unity server mailbox to leave the voicemail in the users mailbox.
For calls from extensions that are on the unity server, unity sees that extension as a subscriber so uses that users mailbox to send the VM. This is why you see a name on these, because it knows it is from the number. Example, if Bob at extension 3000 calls Joe at extension 3010, when the call rolls to VM unity see's it is 3000 calling 3010 and has a subscriber with extension 3000 and another with extension 3010 so it can populate both names.
There is a seperate subject line customization for external calls, then internal calls so you can make the external calls from non-subscribers subject different.
