What are the FWSM: FLAGS - Bs Ba B ?
Answered Question
Feb 1st, 2007
Does anyone know what the flags Bs Ba B means?
When show connections on the FWSM i get:
Firewall# sh conn for x.x.x.x
316 in use, 794 most used
Network Processor 1 connections
TCP out x.x.x.x:1078 in y.y.y.y:3128 idle 0:00:18 Bytes 66 FLAGS - Bs
TCP out x.x.x.x:1078 in y.y.y.y:3128 idle 0:00:18 Bytes 264 FLAGS - BA
TCP out x.x.x.x:1079 in y.y.y.y:3128 idle 0:00:04 Bytes 66 FLAGS - B
TCP out x.x.x.x:1079 in y.y.y.y:3128 idle 0:00:04 Bytes 198 FLAGS - BA
Network Processor 2 connections
Multicast sessions:
IPv6 connections:
Best Regards
Jarle
Correct Answer by gagansethi about 9 years 8 months ago
refer to the below link for flag details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_3_1/fwsm_ref/s2.htm#wp2639649
hope this helps understanding each sequence with associated flags.
gagan
Overall Rating: 4 (2 ratings)
