Configuring Secondary ACS Server
i am prepared to configure ACS Replication between my two SecureACS Servers vs 3.2. My question is, how am i supposed to configure both TACACS Servers in the configuration of let's say a router if the primary fails? As far as i know the IOS will accept only one "tacacs-server host 172.x.x.x" command.
Overall Rating: 5 (1 ratings)
gagansethi Fri, 02/02/2007 - 01:52
just add another TACACS+ server below the first one. The router will always communicate with the first listed TACACS+ server in the list, as soon as the first one fails the router will try reaching the second TACACS+ server listed below.
the command for mentioning second TACACS+ server is same as you have mentioned above.
thanks,
gagan
