How to recover LOC2710 passwords
Feb 1st, 2007
How to recover Location server 2710 passwords?
The location server 2710's GRUB menu is not show up during booting.
carenas123 Thu, 02/08/2007 - 12:30
If you lose or forget the root password for the Location Appliance, you can recover the password with these steps:
Once the GRUB screen comes up, press Esc to enter the boot menu.
Press e to edit.
Navigate to the line that begins with "kernel," and press e.
Press b to begin boot. The boot sequence can commence, and at the end the user is given a shell prompt.
The user can change the root password with the passwd command.
Enter and confirm the new password.
Reboot the machine
yong1794 Fri, 02/09/2007 - 02:05
Thanks your reply.
But The GRUB screen is not comes up.
Booting is go on without GRUB screen. This is problem.
o-ziltener Sat, 02/17/2007 - 03:27
Hello
I have the same problem.
Did you already find a way to fix it?
thanks oliver
yong1794 Sat, 02/17/2007 - 16:02
NO, I've not find passwords recovery way.
Maybe i have to RMA.
Thanks.
Trending Topics - Security & Network
