Clamping down bandwidth
Feb 2nd, 2007
All,
I am trying to set up a dummy site on our Head Office LAN across the CAT5 infrastructure. This is to mimic one of our remote sites for a new business application trial on bandwidth. I have 2 routers set up through their ATM ports and wish to clamp the WAN interface to the ADSL speeds of 1MB and 256. Below is the result of a show version, can anyone advise any commands to complete this task?
IOS (tm) C828 Software (C828-OY6-M), Version 12.3(5b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Jan-04 08:44 by kellythw
Image text-base: 0x80013148, data-base: 0x807663EC
ROM: System Bootstrap, Version 12.2(1r)XE2, RELEASE SOFTWARE (fc1)
Test_Store_Remote uptime is 1 week, 6 days, 16 hours, 54 minutes
System image file is "flash:c828-oy6-mz.123-5b.bin"
CISCO C828 (MPC855T) processor (revision 0x401) with 31744K/1024K bytes of memory.
Processor board ID FOC08078HH6 (2011490387), with hardware revision 0000
CPU rev number 5
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Darren.
mheusinger Fri, 02/02/2007 - 01:05
you can use shaping to achieve your goal.
policy-map Shape256
class class-default
shape average 256000
interface Ethernet0
service-policy output Shape256
This will limit your outgoing traffic to 256 kbps. The detailed description of Shaping can f.e. be found in "Configuring Class-Based Shaping"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd8f0.html
Hope this helps! Please rate all posts.
Regards, Martin
5c5administrator Fri, 02/02/2007 - 04:26
I have set this script and it has accepted all commands. The only issue is when I complete a show run it does not display the service-policy on the ethernet0 interface. Does these might it did not accept the command?
Darren.
