CCME select dial-peer
Feb 2nd, 2007
Hi, my customer has connected two gateways gsm to the ccme. Could be possible select one or another to out mobile calls in function on the calls hour ?
Many thanks,
DS
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Fri, 02/02/2007 - 02:48
No, not directly. You will need an external script that change configuration to do this.
