LLQ / CBWFQ on 3550 switch
Feb 2nd, 2007
We are trying to configure QoS on 3550 switch L3 interfaces.
The IOS running is c3550-ipservices-mz.122-25.SEE2.bin
We are facing the following problem
1. Trying to configure Policy-Map and Class-Map
2. Under Policy-Map when getting into Class-Map config mode, we are not getting any command option as bandwidth or Priority. Only the following options are seen under class-map config mode.
police
set
trust
Can somebody tell us what could be the problem?
Sebastian
Overall Rating: 4 (1 ratings)
mheusinger Fri, 02/02/2007 - 02:07
all the options you have are described in "Configuring QoS" from "Catalyst 3550 Multilayer Switch Software Configuration Guide, Rel. 12.2(25)SE"
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00802cb831.html
It tells you, that queueing is configured quite different to a router. The commands for queueing in the 3550 start with "wrr-queue..." and are configured on an interface basis.
So your "problem" is a different QoS implementations on Catalyst switches compared to routers.
Hope this helps! Please use the rating system.
Regards, Martin
