PIX interfaces ????
Feb 2nd, 2007
hi
we are configuring a PIX 525 and facing a prob that after assing the Ip add to an interface we have observed that interfce is administravitivly Down what can i do,,
I have read on cisco site intsert new card in it and than use write mem for it i could nt unserstand it .. can you tell us abuot it..
which new card ????
Thanks and regards
Overall Rating: 4 (2 ratings)
vijayasankar Fri, 02/02/2007 - 03:23
By default all the interfaces will be in shut state in the configuration.
Try issuing "no shut" on the interface configuration mode and saving the configuration.
-VJ
talisman1310 Fri, 02/02/2007 - 04:02
doind a no shut in the particular interface will not work for a firewall.
Try the following syntax....
interface < hardware_id>
eg:
interface ethernet0 100full
interface ethernet1 100full
