CallManager
Feb 2nd, 2007
Hi, can anyone tell me how to fix this error? And can you explain what it means? Thanks!!
Event Type: Error
Event Source: DCOM
Event Category: None
Event ID: 10009
Date:
Time:
User: CMPUB\SQLSvc
Computer: CMPUB
Description:
DCOM was unable to communicate with the computer IS~CMSUB1 using any of the configured protocols.
Overall Rating: 4.5 (2 ratings)
jbarcena Fri, 02/02/2007 - 05:47
This is usually a microsoft issue, please check this documents:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/w2kmsgs/403
4.asp
http://www.eventid.net/display.asp?eventid=10009&eventno=579&source=DCOM&pha
se=1
http://support.microsoft.com/default.aspx?scid=kb%3BEN-US%3BQ245197
If that is not the problem I have also seen that rebooting the servers in the cluster help
(if the name of the computer that you are seeing in the error is the publisher or one
subscriber).
If after the reboot the errors are still showing please also check that the host and
lmhost files are updated. Do the following:
Use Notepad (select Start > Programs > Accessories > Notepad; click File > Open) to open the file named hosts, which is
located in the folder C:\WINNT\system32\drivers\etc\.
At the end of the hosts file, append a new line for all servers in the CallManager cluster & the Unity server. Leave a tab between the IP and hostname:
<#PRE>
For example,
192.168.1.1 PUBCCM1 #PRE
192.168.1.2 SUBCCM1 #PRE
192.168.1.3 SUBCCM2 #PRE
Do the same with the lmhosts file.
Afetr updating the hosts and lmhosts, please open a DOS window and run the following
commands:
C:\>nbtstat -R
C:\>nbtstat -c
//Jorge
nschlutter Mon, 04/09/2007 - 12:24
These errors can also occur if the MCS server has dual NICs and only one is connected and the other interface is NOT disabled. By default the unused network interface is disabled during the install process.
