Security Certification
Feb 2nd, 2007
I want to take a help regarding Security Certication. I would like to give Certifications regarding Security, can anybody guide me from where to start.
Best Regards,
Rahim Amir Ali
Overall Rating: 5 (1 ratings)
glengregory Fri, 02/02/2007 - 23:52
There are plenty of Security certs right now (in general). In Cisco, it's the CCSP track.
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
It all depends at what stage of your career you are in, your experience in networking / security field, your job, the country you live in & most importantly, what you like best & where you want to be years from now foresight)?
The links below should answer your queries:-
Guide to vendor-specific security certs
http://searchsecurity.techtarget.com/tip/0,289483,sid14_gci1033952,00.html
Analysis: The vendor-neutral security certification landscape
http://searchsecurity.techtarget.com/tip/0,289483,sid14_gci1045073,00.html
SearchSecurity.com Guide to Infosec Certifications
http://searchsecurity.techtarget.com/tip/0,289483,sid14_gci1044613,00.html
Glen
waridtel.com Tue, 02/06/2007 - 04:10
Thanks for your reply. I am focusing on Cisco Certification and I am at the mid stage of my career.
I just want to discuss which Certification in CCSP should i go first.
Best Regards,
Rahim Amir Ali
glengregory Fri, 02/09/2007 - 00:01
The order people recommend on this forum is this:-
SNRS
SNPA
IPS
CSVPN
SND
Glen
