MSFC card not loading on SUP2 Module (6509)
Feb 2nd, 2007
I have a load issue I cannot seem to rectify.
When the SUP2 module loaded the CatOS 6.3.3 I went into session 15 to access the MSFC card I found the prompt was router(boot)
I guess this mean that no valid IOS was found on the bootflash:
I did a dir bootflash: and found 2 versions of IOS to load.
I went into "conf t" and did a boot system bootflash:<IOS filename> and reloaded the 6500.
Session 15 no longer comes online. I guess the IOS was corrupt or invalid.
I cannot seem to get into session 15 anymore.
I do a show module 15 and it tells me the module is offline
Any ideas.
pciaccio Fri, 02/02/2007 - 04:07
Try using the SWITCH CONSOLE 15 command to get into the MSFC. From their you can set up the correct IOS to boot off of..Good Luck....
glen.grant Fri, 02/02/2007 - 04:47
Check the config register on the msfc and make sure it is 0x2102 and the image you are trying to load is a valid Sup2 MSFC image.
