cisco6513 sup720 in slot 8 booting by default
Hi Net Pros...I setting up a new 6513, and observe that the sup720 engine in slot 8 boots by default. But when I failover the sup engine in slot7 is take over and working fine.
'sh mod' and diagnostics doesn't detect any issue with both sup engines. Anybody had faced any similar issues? or any bugs with IOS 12.2(17d)SXB1 might causing this? Any help?
Thanks in advance.
eofelt Fri, 02/02/2007 - 06:37
How are you performing failover?
-HSRP?
-Blade removal etc ?
eofelt Fri, 02/02/2007 - 11:55
Both sups will be tested at POST and after POST the standby sup will -seem- to be inactive but if everthing is working correctly there will be no issue.
To support this, perform a sh mod after the switch is completely up.
One will be marked HOT and one Active.
also, show redundancy.
I hope I am understanding your question. Please post outputs if needed.
HTH, please rate for me
