VPN conncetion via PIX 501
Feb 2nd, 2007
I got a problem with a Cisco PIX 501.
The network equipment changed (Modem) and also the IP Addresses.
I changed the IP Addresses on the PIX and on our concentrator where the vpn tunnel will be terminated.
So the modem/router is configured with 2 offical IP Addresses - one on the outside and one on the inside connection.
he pix also got an offical IP Address from the same network.
Internet is working - I can ping from the pix to any offical IP?s.
When the pix tries to establish the vpn connection, I got this error message on the concentrator:
13180 02/02/2007 14:05:09.620 SEV=4 IKEDBG/65 RPT=22091 <IP OF THE PIX>
IKE MM Initiator FSM error history (struct &0x3badffc)
<state>, <event>:
MM_DONE, EV_ERROR
MM_WAIT_MSG2, EV_RETRY
MM_WAIT_MSG2, EV_TIMEOUT
MM_WAIT_MSG2, NullEvent
What can be the problem ?
I?ll try to reach the pix via telnet and I will then post the output of crypto ipsec
Best regards
Kai
ggilbert Fri, 02/02/2007 - 10:11
Kai,
Complete debugs/config from the concentrator the PIX would be a start in the right direction
deb cry isa
deb cry ipsec
Gilbert
