Wireless Control Server (WCS) Password Recovery ?
Answered Question
Feb 2nd, 2007
Is there a way to recover/change an admin password on a WCS server, or is the best bet to uninstall/reinstall WCS. I can't find any documenation on cisco.com mentioning password recovery on WCS. Thanks!
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Jennifer,
I would open up a Tac case, there is a bug (listed below) that would indicate to me that Cisco may be working on this issue. The current prescribed workaround is, as you noted, uninstall/reinstall;
CSCsg46139 Bug Details
Headline WCS needs password recovery mechanism without losing database
Product wcs
Symptom:
Administrative password to WCS is lost; need to recover access.
Workaround:
Reinstall WCS.
Further Problem Description:
It would be nice to be able to recover access to WCS, after a lost password,
without losing the database.
From this WCS doc;
CSCsg46139 If you lose your WCS password and have not backed up your database, there is no mechanism to recover the password.
http://www.cisco.com/en/US/products/ps6305/prod_release_note09186a00807bd545.html#wp17024
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Fri, 02/02/2007 - 07:46
Hi Jennifer,
Product wcs
Symptom:
Workaround:
Reinstall WCS.
From this WCS doc;
Hope this helps!
Rob
Jennifer Huber Fri, 02/02/2007 - 07:48
Thanks very much - since I couldn't find anything - I was pretty sure uninstall/reinstall would fix it.
joeferdinandi Mon, 06/18/2007 - 08:51
Jennifer,
While trying to recover WCS were you able to save the WCS database?
Joe
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
