CCNA IOS software
Feb 2nd, 2007
Im working on my CCNA
And would like to update the IOS on some 2500
Series routers, does Cisco have away for somebody
Not in a corp., to have access to IOS images,
Even if I need to pay for IOS images, or license for IOS,
Thanks for any help,
devang_etcom Fri, 02/02/2007 - 10:54
i think you will not get it very easy?
try to search some thing like "IOS Hunter" on google... and when you find the then download its trail version it will allow you to download the basic IOS... if you want full version then you need to pay 60$...
all the best for CCNA
rate this post if it hleps
regards
Devang
cmptrgydv Fri, 02/02/2007 - 13:09
Thanks for the reply,
How would I go about paying the $60
Is that the cost of being a registered user?
Do I need to be affiliated with a company to join as a registered user?
