Trigger a Script from a timer?
Feb 2nd, 2007
Any recommendations on the cleanest way to trigger a script on a timed basis, i.e. every 5 minutes? (IPCCx 4.04 Premium)
Dennis Fogler Sun, 02/04/2007 - 10:37
The easiest way I have found to do this is to use an http trigger, on IPCCx, to call the script. Then use a VB Script to call the trigger on a predetermined interval. For example:
I used the following code to launch a background process of IE.
Set objExplorer = CreateObject("InternetExplorer.Application")
objExplorer.Navigate "http:\\:8080/"
objExplorer.Visible = 0
Note the value of the obj.Navigate object is set the http trigger that you set up on IPCCx where is the ip address or DNS name of IPCCx & is the trigger on IPCCx.
I then wraped this code in a Do While statement to control the flow of when the trigger is called.
Do While ...
Loop
I hope helps get you going in the right direction.
biffhansen Wed, 02/07/2007 - 15:16
Dennis, Thank you, works fine.
Didn't know if someone might have a shortcut via jtapi.
Biff
