SSH 4003/4006
Answered Question
Feb 2nd, 2007
Hi All
Please can you tell me what CatOS version can go onto the Cat 4003 and Cat 4006 that will support SSH?
We have
1000BaseX Supervisor: WS-X4013
Switching Supervisor: WS-X4012
Correct Answer by Amit Singh about 9 years 7 months ago
For SSH you need K9 images for sure. You dont need K8 images and will not work for you. I think there is some problem with the software advisor. Please look at the release notes below.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_1983.htm
HTH,Please rate if it does.
-amit singh
Correct Answer by glen.grant about 9 years 7 months ago
Any image that has K9 in the middle will support SSH .
Overall Rating: 5 (2 ratings)
Correct Answer
glen.grant Fri, 02/02/2007 - 09:18
londint Sun, 02/04/2007 - 23:37
Thanks.
While using the hardware feature of the Software Advisor, it recommends a K8. Will this do and what is the difference. Why a K8 and not a K9?
