High CPU on IPCC Express 4.0(4)SR1 - FCVoIPMonSvr.exe
Feb 2nd, 2007
For the last 24 hours, CPU on our Primary CRS Engine has been very high (80 - 100%). Taskmgr shows the primary culprit as as FCVoIPMonSvr.exe. If I kill this process, CPU returns to normal levels for about 30 seconds, then process comes back and we're back to square one.
I'm assuming this has something to do with Voice Monitoring, and we do have the service active but no one is currently using it. Upon killing the process, I messages flooding event viewer saying "Error: in retrieving mac address for agent (XXXX) Error (36: no more records found)". No other abnormalities have been found in the logs so far.
Other than the high CPU, everything seems fine (CTI ports registered, applications working, agents can log in, Historical Reports OK, etc). But obviously I'm concerned about this and was wondering if anybody's seen it before.
johnnylingo Fri, 02/02/2007 - 21:42
Temporarily got the CPU back to normal levels by stopping the VoIP Monitoring Service in Control Center.
Paulo Pereira Sun, 02/04/2007 - 07:00
Johnny,
You need to run the PostInstall Tool (aka the "CAD Configuration Setup Tool") on the IPCC Express server and select a valid NIC for the VoIP Mon service.
Please refer to the "CAD Configuration Setup" section of the CAD Installation Guide for more details about launching/using the PostInstall Tool:
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_0/english/agents/cad611ig.pdf
If you continue to have problems, please open a Service Request with TAC.
Thank you.
