Logging on a router
I have a problem when an admin logged in to a router it doesn't show when that person logged in. It only show when he do a change on a router and do wr memory. Here is config I have. Please help. Thanks
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
logging buffered 4096 debugging
logging console informational
logging monitor informational
logging facility local6
logging source-interface FastEthernet0/0
logging 10.17.84.7
pmccubbin Fri, 02/02/2007 - 12:02
I've only seen what you are asking for when an authentication server such as a TACACS server was being used.
The config you have shown the forum will only display in the config when a change is made on the router and/or when a config is saved to memory.
Hope this helps.
daviddtran Sun, 02/04/2007 - 11:16
you need AAA accounting for this. Here is how:
aaa new-model
aaa authentication login notac none
aaa authentication login VTY group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization exec notac none
aaa authorization exec VTY group tacacs+ if-authenticated none
aaa authorization commands 0 VTY group tacacs+ if-authenticated none
aaa authorization commands 1 VTY group tacacs+ if-authenticated none
aaa authorization commands 15 VTY group tacacs+ if-authenticated none
aaa authorization network VTY group tacacs+ if-authenticated none
aaa accounting exec TAC start-stop group tacacs+
aaa accounting exec VTY start-stop group tacacs+
aaa accounting commands 0 TAC start-stop group tacacs+
aaa accounting commands 0 VTY start-stop group tacacs+
aaa accounting commands 1 TAC start-stop group tacacs+
aaa accounting commands 1 VTY start-stop group tacacs+
aaa accounting commands 10 TAC start-stop group tacacs+
aaa accounting commands 15 TAC start-stop group tacacs+
aaa accounting commands 15 VTY start-stop group tacacs+
aaa accounting network VTY start-stop group tacacs+
aaa accounting connection TAC start-stop group tacacs+
aaa session-id common
line vty 0 15
accounting exec VTY
login authentication VTY
You can see everything what the user is doing via tacacs accounting log
med_ddevlin Sun, 02/18/2007 - 19:41
I'm not sure which version IOS you are running but 12.3(4) and up have config change logging and notification built-in already. You would just have to enable that feature.
To enable this just enter:
Config Mode
logging enable
archive
log config
hidekeys (hides passwords)
notify syslog
With this you can base alerts off what is sent to the syslog server.
