Multicast Traffic on switch
Feb 2nd, 2007
How do I limit Multicast traffic on a switch. I have a switch (switch A) on the network that I use for imaging new PC. The image server (Ghost) and the PC's are connected to this switch A and switch A has a trunk to other switch on the network.
When I start imaging, the whole network comes down as a result of multicast traffic. I have enabled ip multicast routing and ip pim sparse-dense mode on the interface vlan, and still the network is affected.
How do I limit Multicast traffic to Switch A, and prevent it from going over the trunk to other switches on the network?
amit.seth Tue, 02/06/2007 - 02:20
Hi Holley,
You could choose any of the following methods depending on your requirement.
1. Switch(config-if)# switchport block multicast Blocks unknown multicast forwarding to the port.
2.If you are open to the trunk port moving to blocking state when there is a flood of Multicast Traffic. You could try the following alternative
Switch(config-if)# storm-control {broadcast | multicast | unicast} level {level [level-low] | pps pps [pps-low]}
The keywords have these meanings:
For level, specify the rising threshold level for broadcast, multicast, or unicast traffic as a percentage of the bandwidth. The storm control action occurs when traffic utilization reaches this level.
Switch(config-if)# storm-control action {shutdown | trap}
Specifies the action to be taken when a storm is detected
3.You can also try and put ACL's on the trunk port for Multicast Traffic(224.0.0.0 - 239.0.0.0). I have not yet tried this.
HTH.
Amit
p.holley Wed, 02/28/2007 - 09:26
I have tried all the above and multicasting still brings down the network.
Sample int config.
int fa0/1
description to other cisco switch
switchport mode access
switchport access vlan 10
storm-control multicast 10
storm-control action shutdown
ip access-group 101 out
access-list 101 deny ip 224.0.0.0 15.255.255.255 any
access-list 101 deny any 224.0.0.0 15.255.255.255
access-list 101 permit ip any any
int vlan 10
ip address
ip access-group 101 in
