MWI Setting Location
Feb 2nd, 2007
Running Unity 4.1 in an off box E2K3 dual integration model (Call Manager 4.1 and Avaya G3R with Digital PIMG Integration). We are in need of changing our MWI codes on the Avaya side and I cannot seem to find where in Unity they are located. I know they used to be in a avaya000x.ini file for the switch, I see it is now referring to a sip0002.ini file that has none of this information in it. Does anyone know where these settings can be changed now?
Paul
pjt8537 Fri, 02/02/2007 - 13:54
Thanks Eric. So, are the lwc-store and lwc-cancel feature buttons on the digital stations taking care of that now? Unity and the PIMG units have no need to have those feature button codes defined any longer? Just curious as I was used to the old method.
Paul
