VPN Client LAN access issues to a remote PIX 525
Feb 2nd, 2007
I have an established VPN connection to a remote PIX 525 from my home office. This is not an IPSec connection. On my side I have a PIX 501 currently running 6.2(2). After establishing a connection I cannot access the remote or my own local LAN network other that to ping the IP addresses assigned to me by the remote firewall or my local network. My PIX 501 appears to be blocking the traffic as I can ping outside addresses from the firewall itself. QUESTION: Is there anything that I need to do on my PIX 501 firewall in order for this to work? I am using the Cisco VPN client Ver 4..8.002.0010 running on Windows XP Pro.
vijayasankar Fri, 02/02/2007 - 20:44
Do you have access to the remote pix configuration details.
If so, kindly provide the remote pix configuraiton and you pix 501's configuration, to check this.
-VJ
