Standard greeings disabled
Feb 3rd, 2007
On Unity 4.2 we occasionaly find some subscribers default greetings are disabled.
All he documentaion, including dbwalker, says this is not possible.
Any ideas what may cause this ?
Running dbwalker does cure the problem
sopayne Mon, 02/05/2007 - 11:39
It sounds like you may be observing a known issue, CSCsg36208:
Symptom:
Under the greetings settings for a Call Handler's Standard greeting, Status
is set to 'Disabled' and is greyed out preventing change. The Standard
Greeting still functions normally.
Conditions:
Reported on a customer system running Cisco Unity 4.2(1). New install.
Workaround:
To correct this status displayed in the SA and/or if the Standard Greeting
truly is disabled then latest version of DBWalker run without any options
selected will correct this. It will display the following message:
Greeting rule Standard
1195:(error) Standard messaging rule was disabled, which should never be
possible.
1253:(fixed) Standard messaging rule automatically enabled.
If running DBWalker does not correct the problem contact TAC for further
assistance.
NOTE: The Standard Greeting is designed such that it can never be disabled,
it plays all the time unless overridden by another greeting.
I hope this helps.
