LMS 2.5.1 (RME)
Feb 3rd, 2007
When i try to update the configuration from RME->Config Mgmt->Config Editor->
Config Editor Jobs. The running configuration becomes updates but not the startup one. i got this message from Config Editor "Deploy succeeded, Synchronization of RME archive with Device Config failed" with the Failed Status
pl. help me to resolve this issue.
miheg Sun, 02/04/2007 - 23:57
So it seems you deployed a new running config.
It's an option in the job to do a write and sync to the startup config.
Or you run a second job to sync all configs that have a different startup and running config.
Cheers,
Michel
Mubasher Sultan... Mon, 02/05/2007 - 02:55
Yes, i want to use the option in the job to do write n sync to the startup config.
The job status is failed and i got this message
