HWIC-1ADSL requires a router reload
Feb 3rd, 2007
I have a 2811 with one HWIC-1ADSL running on 12.4(11)T. The internet on this router keeps stoping. When it happens, the CD and OK leds on the router are solid green and the "show interface" command shows the interface and the line protocol up but no traffic is sent/received on the interface. The only way to get the internet up again is restarting the router. Has anyone had the same problem?
drew.freeman Mon, 08/20/2007 - 16:54
You need to use 11T2 image or higher which supposedly has the fix for this bug. However we are still seeing this problem occur occasionally.
But I'm surprisd you didn't know this as I work with you ;o)
