G.703 module not recognozed in 2801
Feb 4th, 2007
I just baught a Cisco 2801 router. After installing G.703 2 MFT card for E1 termination i can't see any interface for the card except 2 Fasthethernet interfaces. I checked all the four slots of router but its not working. Is it a IOS issue?
sachinraja Sun, 02/04/2007 - 17:28
Hello fahad,
I just ran a software advisor for your requirement, and found that the following IOS software fits fine for the 2 Port RJ-48 Multiflex Trunk-g.703 module... I was actually searching for a ipbase image..
1) 12.4(9)T2
2) 12.4(8c)
3) 12.3(11)YK2
4) 12.3(14) T7
You need to have these IOS to run this module.. what IOS feature set do you have now? change the IOS, and it should work fine..
Hope this helps.. all the best..
Raj
