Can't log in SSM-10
Feb 4th, 2007
Dear All,
I had ASA 5510 and modul SSM-10.Could you tell me, I want to reset default factory (configuration)on SSM-10 Because I can't log in Trend Micro Content Security.
Best Regard,
nareth_norung Sun, 02/11/2007 - 18:52
Dear Sir,
Thank you for support.Ok,Now i can login to CSC SSM-10.Right now i have one problem,CSC setup wizard in step 5 it nearly finish it show dialog typ Old password and newpassword.It show error message (The old password is not correct,Please enter the corrent password. which command reset password ? please find attach file.
Best Regard,
