Connection drops randomly
Feb 4th, 2007
We are using 3560's. Switches are split with 5 VLans. On one particular vlan we have had several users connections just drop off for a few minutes, then reconnect, this happens throughout the day. I've failed to see what is causing this, any ideas?
I am going to upgrade the IOS to see if that helps.
We are currently using Version 12.2(25)SEB4
kpmgnz Tue, 02/06/2007 - 17:51
No they don't.
Are you able to tell me what these entries mean. From the 'show run' there are several ports that have the following entries and some don't have them?
switchport port-security
switchport port-security maximum 3
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
Thanks again
nyr.hakeem-habeeb Wed, 02/07/2007 - 04:29
This configuration is to enable port-security on individual switchports.
- This enables port security on the port
- This sets the max. number of MAC addresses that can be learned on that port to 3
AND
- Sets the aging time of the "Secure MAC address" learnt on port to 2min, and deletes the secure MACs after 2min of inactivity.
- When the number of MACs learned on the port exceeds 3 packets from other sources would be dropped.
I guess this would be the root of the connection drops.
Thanks.
kpmgnz Sun, 02/11/2007 - 12:53
I have removed the swithport security, however if I place a call to an ext with the existing problem, the call drops off after 20 seconds. - The phone reports Call Manager unavailable.
