How to set up a multi-vlan port
Feb 4th, 2007
Hi, I am having problems in setting up a port to join more than 1 vlan using a 2960g router.
Whenever I try to add that one port to another vlan, it disappears from the previous one.
The setup I need requires that a server can visit clients, however each client can only visit the server, communication between clients is forbidden. I created a vlan for each client so that they are separated but I need to add the server port to the client vlan as well.
Jon Marshall Mon, 02/05/2007 - 00:12
if you have a layer 3 device you could use access-list to restrict traffic flows between clients and between the clients and the servers.
If you are trying to do this at layer 2 only i think you can still use access-list although you would need to have all your clients and the server in the same vlan.
Attached is layer 2 access-list config guide for 2960 switch
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a00805a75be.html
Jon
wilbertchoa Mon, 02/05/2007 - 01:17
From what I read in the document, I seem to be able to only filter inbound access to the whole network and not per client using my existing hardware.
I may occasionally need to let each client access the internet through the server so I'm not sure if I can do that in addition to denying access
Sorry, if i misunderstood, I'm not really very knowledgeable in networking yet.
Looks like I need to use some other switch for what I require.
Jon Marshall Mon, 02/05/2007 - 01:31
Maybe i misunderstood the requirements. I was thinking you could do the following
access-list 101 permit ip host "client ip address" host "server ip address"
access-list 101 deny ip any any
Then apply access-list 101 to the client interface.
eg
interface "interface id"
ip access-group 101 in
This would allow the client to talk to the server but not to anything else with the vlan.
You could create separate access-lists for each client.
For the server you wouldn't need an access-list.
As mentioned before all clients + server would need to be in same vlan.
Does this not do what you want it to do.
Jon
