Restric calls to International base on Calling number.
Feb 5th, 2007
I have the network as follow
PSTN, International--Cisco AS5300--gk--CCM (4.1(3)SR3C)--IP Telephony (IP Phone, ATA...).
So I want a specific DN under CCM controlled NOT BE able to call outside PSTN or International. Pls help me!!!
Overall Rating: 5 (1 ratings)
jbarcena Mon, 02/05/2007 - 05:37
This is really easy, you have two options:
1.- Since the Route Pattern that is used to dial International calls has a Partition you
can remove this partition from the CSS of the phones that you want to block from dialing
International Calls.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/index.htm
2.- You can use a FAC (Forced Authorization Code), with this feature after dialing the
International number you will need to dial a code and then press # to route the call
otherwise it will never go out.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmfeat/fsfaccmc.htm#wp15243
The same principle applies for PSTN numbers.
//Jorge
