Aux Port
Feb 5th, 2007
I have a VoIP configured on a 3600 router.
I want to configure the Aux Port to connect remotly.
Can you help?
ffragoso Mon, 02/05/2007 - 11:48
Can you give me a little more detail on what exactly your trying to do and how you are trying to connect remotely?
ericdegboevi Tue, 02/06/2007 - 09:00
i was told that a remote connection is possible through Aux port on the router if i can't access the router through Fa interface as the router is configure with private IP and i want access over the internet.
The router is configure for VoIP.
I will aprecial any help.
Thanks, Eric
