SwitchA
lgijssel Mon, 02/05/2007 - 04:03
You could use a script to disable the ports and then a second script to re-enable them at the desired moment.
scripts could be something like:
!disable-script
int ra fa0/1 - 23
shut
end
!re-enable-script
int ra fa0/1 - 23
no shut
end
This presumes your mgmt connection is on fa0/24 which should hence not be disabled.
Leo
nyr.hakeem-habeeb Mon, 02/05/2007 - 11:05
would also you could like to add; you could also look at QoS to prioritize your backup traffic to ensure this will always get highest priority over any user traffic. Assuming your goal is not to have failed backups due to contention.
HH
