5 users limitation using PPPoE on cisco??
Answered Question
I am trying to use a cisco as a pppoe server. The problem is that its not able to connect mor e than 5 users at a time. I thought the cisco(3620) had some problems and used another (2610) with the same result. What could be the problem?
TIA
Shekhar Basnet
Here are some info.
System image file is "flash:c2600-ik9o3s-mz.122-31"
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
PPPoE# sho run
Building configuration...
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group canopy-consumer
accept-dialin
protocol pppoe
virtual-template 10
pppoe limit per-vlan 300
interface FastEthernet1/0.630
description #### PPPoE clients #####
encapsulation dot1Q 630
pppoe enable
interface Virtual-Template10
ip address 192.168.125.125 255.255.255.252
peer default ip address pool consumer-pool
ppp authentication pap
ip local pool consumer-pool x.x.254.112 x.x.254.119
Here's a sample log when trying to connect using a 6th customer
Feb 5 16:49:53: PPPoE 0: I PADI L:ffff.ffff.ffff R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:53: PPPoE 0: O PADO L:f730.8100.0276 R:ba27.0003.e3e8 630 Fa1/0.630
Feb 5 16:49:53: PPPoE 0: I PADR L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:53: PPPoE 396: Creating
Feb 5 16:49:53: PPPoE 396: Created L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:53: PPPoE 396: O PADS L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:53: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
Feb 5 16:49:54: PPPoE 396: I PADT L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:54: PPPoE 396: Shutting down
Feb 5 16:49:54: PPPoE 396: O PADT L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:54: PPPoE 396: Destroying L:0003.e3e8.f730 R:000a.e44f.ba27 630 Fa1/0.630
Feb 5 16:49:54: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
PPPoE#sho idb
Maximum number of IDBs 300
24 SW IDBs allocated (2624 bytes each)
19 HW IDBs allocated (4976 bytes each)
HWIDB#1 1 Ethernet0/0 (HW IFINDEX, Ether)
HWIDB#2 3 BRI0/0 (HW IFINDEX, HW ISDN, Serial)
HWIDB#3 4 Serial0/0 (HW IFINDEX, Serial)
HWIDB#4 5 BRI0/0:1 (HW ISDN, Serial)
HWIDB#5 6 BRI0/0:2 (HW ISDN, Serial)
HWIDB#6 7 Serial0/1 (HW IFINDEX, Serial)
HWIDB#7 8 FastEthernet1/0 (DOT1Q, HW IFINDEX, Ether)
HWIDB#8 9 Virtual-Access1 (Serial, HW VACCESS)
HWIDB#9 10 Virtual-Access2 (Serial, HW VACCESS)
HWIDB#10 11 Virtual-Access3 (Serial, HW VACCESS)
HWIDB#11 12 Virtual-Access4 (Serial, HW VACCESS)
HWIDB#12 13 Virtual-Access5 (Serial, HW VACCESS)
HWIDB#13 14 Virtual-Access6 (Serial, HW VACCESS)
HWIDB#14 15 Virtual-Template10 (HW IFINDEX, Serial, HW VTEMPLATE)
HWIDB#15 16 Loopback0 (HW IFINDEX)
Correct Answer by Makarand Chitale about 9 years 7 months ago
This will happen when using an ip address on the VT itself, instead make it ip unnumbered.
You have:
Change to:
interface loopback 100
ip unnumbered loopback 100
Please post further questions in the Ask-the -expert session I am holding.
Mak
Overall Rating: 5 (1 ratings)
Correct Answer
Makarand Chitale Wed, 02/07/2007 - 13:41
You have:
Change to:
Mak
Yahoooo!! Success at last.. Thanks a lot Mak. But I would love to know the reason behind it. So even changing the subnet on VT to /24 would have had no effect then?
PPPoE#sho user
Line User Host(s) Idle Location
* 66 vty 0 shekhar idle 00:00:00 x.x.233.248
Interface User Mode Idle Peer Address
Vi1 silt Virtual PPP (PPPoE ) 00:00:05 x.x.225.35
Vi2 hhc123 Virtual PPP (PPPoE ) 00:00:15 x.x.225.37
Vi3 mahaguthi Virtual PPP (PPPoE ) 00:00:55 x.x.225.33
Vi4 atlas Virtual PPP (PPPoE ) 00:00:35 x.x.225.36
Vi5 hope Virtual PPP (PPPoE ) 00:01:35 x.x.225.34
Vi6 ktptest Virtual PPP (PPPoE ) 00:00:05 x.x.225.38
PPPoE#
