ACS 4.0 and IBM TSCM
Answered Question
Feb 5th, 2007
I try to load NAC attributes for IBM Corporation (TSCM) from ftp server (NAC Attributes Management), but these don't appear in System
Configuration -> Logging Configuration -> CSV Failed Attempts File Configuration or CSV Passed Authentications File Configuration.
My server is ACS 4.0 appliance. On ACS 3.3 my NAC attributes is works well.
[attr#0]
vendor-id=2
vendor-name=IBM Corporation
application-id=50
application-name=SCM
attribute-id=00020
attribute-name=Policy Version
attribute-profile=in out
attribute-type=string
[attr#1]
vendor-id=2
application-id=50
attribute-id=00021
attribute-name=Violation count
attribute-type=unsigned integer
[attr#2]
vendor-id=2
application-id=50
attribute-id=00010
attribute-name=Action
attribute-profile=out
attribute-type=String
I loaded list with attributes for Symantec on ACS 4.0 and these is OK, but for Tivoli Security Compliance don't works.
PLS, help me if you have a solutions!
Thanks!
Correct Answer by chenyokechuan about 9 years 4 months ago
Yup, you can't have a space between the vendor-name, i have case that after loaded the file i can't see the attribute from ACS Appliance, but can see it appear at logging. After reboot the ACS SE it ok.
I have NAC deployment with IBM TSCM also, can you share the experince? what version of TSCM client we should use? i only can get the version 5.1.0 but it look like need version 5.1.2 above only can patch the latest update.
Overall Rating: 3 (1 ratings)
mugurelgherghe Thu, 05/03/2007 - 03:52
It works with:
[attr#0]
vendor-id=2
vendor-name=IBM_Corporation
application-id=50
attribute-id=00020
[attr#1]
vendor-id=2
application-id=50
attribute-id=00021
[attr#2]
vendor-id=2
application-id=50
attribute-id=00010
Without "space" character in vendor-name.
Correct Answer
chenyokechuan Sun, 05/20/2007 - 07:00
mugurelgherghe Sun, 05/20/2007 - 22:28
Hi!
I want to use IBM Tivoli Security Compliance Manager V5.1.1.1. PLS tell me what remediation server use. TPM?
Thanks!
