Error in Communicating with DCA Server
Answered Question
Feb 5th, 2007
I've upgraded LMS 2.2 to LMS 2.5. After login as admin, in CS when I'm trying to check "Device and Credentials" -> "Device Management"
I get the error:
"Error in communicating with DCA Server.
DCA Server may be down. Please start the DCA Server and then refresh the page."
I've tried to lunch this daemon from command line:
D:\CSCOpx\bin>pdexec DCRServer
ERROR:Get reply from server failed:
D:\CSCOpx\bin>pdshow DCRServer
Process= DCRServer
State = Waiting to initialize.
Pid = 6920
RC = 0
Signo = 0
Start = 02/05/2007 11:41:32 AM
Stop = Not applicable
Core = Not applicable
Info = Server started by admin request
Does anyone knows how to solve this problem?
Platform:
Windows 2000 SP4
CS 3.03
Correct Answer by Joe Clarke about 9 years 7 months ago
Is the LABSERVER10 the current hostname of this machine? Is the SSL port currently 443?
Overall Rating: 5 (2 ratings)
David Stanford Mon, 02/05/2007 - 06:31
Are there any other processes down in the output of pdshow?
Also, have you tried to recreate the certificate?
--Server > Security > Single-Server Management > Certificate Setup and
choose "Apply". Once this is corrected, DCR should startup without this error.
Remember to restart the daemons.
l.szymanski Tue, 02/06/2007 - 02:45
I've recreated the cert and restarted the daemons, but the error still persist.
In the DCRServer.log I have:
[ Tue Feb 06 10:08:48 CET 2007 ] Starting DCR Server...
[ Tue Feb 06 10:08:51 CET 2007 ] No restore has happened
In the syslog.log:
Feb 06 10:54:45 127.0.0.1 100: <28> dmgt[4520]: 2005(W):Internal Error: The maximum number of retry attempts (3) to restart application (DCRServer) has been reached. This application will not be restarted. Call your technical support representative for assistance.
Output from the pdshow command (only daemons which are not runing):
Process= UTMajorAcquisition
State = Never started
Process= EDS-TR
Process= RMEDbEngine
State = Program started - No mgt msgs received
Process= DeviceDiscovery
State = Transient terminated
Process= DCRServer
Process= CampusOGSServer
Process= CMFOGSServer
Process= ConfigMgmtServer
Process= EssentialsDM
Process= NCTemplateMgr
Process= NetShowMgr
Process= RMEOGSServer
Joe Clarke Tue, 02/06/2007 - 10:23
What errors do you see in the dcr.log? You may need to enable DCR debugging in NMSROOT\lib\classpath\com\cisco\nm\dcr\log4j-dcr.properties (back this file up, then change all instances of FATAL, INFO, and ERROR to DEBUG, then restart dmgtd).
l.szymanski Wed, 02/07/2007 - 00:59
Here is the log:
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - urn:EventListenerDCR host:LABSERVER10 CTMClientProperties:Encoding style:1URL:443/cwhp/CTMServlet
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.common - classLocation is: jar:file:/D:/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib/ctm.jar!/com/cisco/nm/xms/ctm/common/CTMConfig.class
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.common - configPath value is: /D:/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib/
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - CTM_URL from config file is ::443/cwhp/CTMServlet
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - Urn:"EventListenerDCR" Host:LABSERVER10 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed Feb 07 09:01:12 CET 2007 ] [main] DEBUG CTM.client - The newly formed URL is https://LABSERVER10:443/cwhp/CTMServlet
[ Wed Feb 07 09:01:13 CET 2007 ] [main] DEBUG CTM.soap - Adding CTMSerializer for DCR , APIExtraInfo , com.cisco.nm.dcr.APIExtraInfo
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.soap - Adding CTMSerializer for DCR , DCRUpdateData , com.cisco.nm.dcr.DCRUpdateData
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.client - Urn:"DCRCAM" Host:LABSERVER10 Encoding style:1URL:443/cwhp/CTMServlet
[ Wed Feb 07 09:01:14 CET 2007 ] [main] INFO CTM.client - Establishing RPC
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.client - Secure Connection is set to TRUE in CTMClientProperties
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.client - Port specified in CTMClientProperties is 80
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.client - The newly formed URL is https://LABSERVER10:443/cwhp/CTMServlet
[ Wed Feb 07 09:01:14 CET 2007 ] [main] DEBUG CTM.client - RPC, EncodingStyle = CTMConstants.CTM_BINARY
[ Wed Feb 07 09:01:20 CET 2007 ] [main] DEBUG CTM.common - classLocation is: jar:file:/D:/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib/ctm.jar!/com/cisco/nm/xms/ctm/common/CTMConfig.class
[ Wed Feb 07 09:01:21 CET 2007 ] [main] ERROR CTM.client - ERR_IN_WRITING_REQUEST, BEFORE_INVOC, Error in writing the request, Binary mode LABSERVER10
[ Wed Feb 07 09:01:31 CET 2007 ] [main] DEBUG CTM.client - RPC, EncodingStyle = CTMConstants.CTM_BINARY
Correct Answer
Joe Clarke Wed, 02/07/2007 - 19:36
l.szymanski Mon, 02/12/2007 - 01:06
I've found out that someone changed hostname after install previous version... I've uninstalled CW LMS and installed again and now is working!
