CCM and IPCC Capacity
Feb 5th, 2007
Hi all,
we have a 7835 CCM Server and IPCC Enterprise
According to this Document:
http://www.cisco.com/en/US/customer/products/sw/custcosw/ps1844/products_implementation_design_guide_chapter09186a00803fb0ac.html#wp1039700
The Capacity of my Callmanager is 125 IPCC Agent.
According to another Document the Capacity of CCM with this Server is 2500 Ip-Phones.
The Question is: If i exceeded the 125 IPCC Agent do i still have capacity available for connecting IP-Phones`? Do the number double if i have a pub and a Subscriber?
JAyD
Brandon Buffin Mon, 02/05/2007 - 13:47
IPCC Enterprise is not supported in a coresident deployment like IPCC Express. In other words, you cannot have CCM and IPCC Enterprise components on the same server. 125 agents is the capacity if this server type is used as an IPCC server. 2500 phones is the capacity if the server is used as a Callmanager.
Theoretically, you could double the number with a Pub and a Sub. You could have 2500 phones registered to each server. The problem with this is that you would have no room for failover. Ideally, if the subscriber is down, those 2500 phones would register to the publisher, but in this case the publisher would already be at capacity.
Hope this helps. If so, please rate the post.
Brandon
