Block call with unknown calling_number
Feb 5th, 2007
Hi!
I have AS5300 with IOS 12.3, this is part of config:
controller E1 5
clock source line secondary 5
pri-group timeslots 1-31
interface Serial5:15
no ip address
no ip route-cache cef
ip mroute-cache
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn incoming-voice modem
isdn guard-timer 3000
isdn bchan-number-order ascending
fair-queue 64 256 0
no cdp enable
voice-port 5:D
disc_pi_off
input gain 3
echo-cancel coverage 32
cptone RU
music-threshold -45
bearer-cap 3100Hz
dial-peer voice 6 pots
incoming called-number .
direct-inward-dial
port 5:D
no register e164
dial-peer voice 7495231 pots
destination-pattern 74952312000
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 5:D
prefix 92312000
If inbound call not match voip peer, call was succesfull and why I can call to PSTN from VoIP whithout voip peer?
How I can block these
calls?
Paolo Bevilacqua Mon, 02/05/2007 - 10:02
what you can do, is to configure a translation profile with a rule that rejects based on calling number, so that is the number is not present in as it should, the call will be dropped.
zaikini_23 Wed, 03/14/2007 - 06:02
Hi, translation profile work's fine, but I don't understand why is calling_party is clean?
I have Cisco 827-4V, this is debug voice translation:
//Mar 14 14:50:28: sed_subst: Successful substitution; pattern= matchPattern=^.* replacePattern=86596300 replaced pattern=86596300//
field "pattern=" is clean
cat config
voice-port 1
cptone RU
dial-peer voice 1 pots
preference 1
answer-address 86596300
destination-pattern 86596300
port 1
dial-peer voice 10 voip
destination-pattern .T
session target ipv4:x.x.x.x
dtmf-relay h245-signal
codec g711alaw
fax rate 9600
ip qos dscp cs5 media
no vad
IOS version
Version 12.2(15)T17
zaikini_23 Wed, 03/14/2007 - 06:49
also I change session protocol, but calling_party is absent.
To: ;tag=3533F110-E7C
Date: Wed, 14 Mar 2007 13:43:11 GMT
Call-ID: [email protected]
Max-Forwards: 6
Content-Length: 0
CSeq: 101 ACK
Paolo Bevilacqua Wed, 03/14/2007 - 10:31
Sorry, I'm lost. Who is calling who? What is is not working, and how would you like it to work?
zaikini_23 Wed, 03/14/2007 - 10:47
I'm sorry,
User1 (TA) -> Cisco 847 -> Cisco AS5300 -> PBX -> User2 (TA)
User1 (calling_party) call to User2 (called_party), call is successfull, but field calling_party is clean, why?
Paolo Bevilacqua Wed, 03/14/2007 - 10:57
OK. Try configuring "station number 86596300" under "voice-port 1", and remove "answer-address" from "dial-peer".
Hope this helps, if so please rate post!
zaikini_23 Thu, 03/15/2007 - 00:18
I change my config, but problem is not disappear
This is part of debug sip session:
To: ;tag=38E0D010-1DAB
Date: Thu, 15 Mar 2007 06:50:52 GMT
CSeq: 102 PRACK
RAck: 4056 101 INVITE
Content-Length: 0
This is session from radius accounting:
Thu Mar 15 09:50:54 2007
Acct-Session-Id = "000A7B67"
Called-Station-Id = "89036295529"
Cisco-AVPair = "[email protected]"
Cisco-AVPair = "iphop=count:1"
Cisco-AVPair = "iphop=hop1:172.31.2.115"
h323-setup-time = "h323-setup-time=09:50:54.230 MSK Thu Mar 15 2007"
h323-gw-id = "h323-gw-id=yyyyyyy"
h323-conf-id = "h323-conf-id=494A72AD D1F811DB 8223E0FA 165EBC44"
h323-call-origin = "h323-call-origin=answer"
h323-call-type = "h323-call-type=VoIP"
Cisco-AVPair = "h323-incoming-conf-id=494A72AD D1F811DB 8223E0FA 165EBC44"
Cisco-AVPair = "subscriber=Unknown"
Cisco-AVPair = "session-protocol=sipv2"
Cisco-AVPair = "gw-rxd-cdn=ton:0,npi:0,#:89036295529"
Cisco-AVPair = "connect-progress=Call Up"
Acct-Authentic = 0
Acct-Status-Type = Start
Service-Type = Login-User
NAS-IP-Address = x.x.x.x
Acct-Delay-Time = 0
Client-IP-Address = x.x.x.x
Acct-Unique-Session-Id = "840e571b8cf90b02"
Timestamp = 1173941454
Thu Mar 15 09:51:00 2007
Acct-Session-Id = "000A7B6D"
h323-setup-time = "h323-setup-time=09:51:00.414 MSK Thu Mar 15 2007"
h323-gw-id = "h323-gw-id=yyyyyyyy"
h323-call-origin = "h323-call-origin=originate"
h323-call-type = "h323-call-type=Telephony"
Cisco-AVPair = "out-intrfc-desc=### second trunk ###"
Acct-Authentic = 0
NAS-Port-Type = Async
Cisco-NAS-Port = "ISDN 2:D:3"
NAS-Port = 0
Acct-Delay-Time = 0
Acct-Unique-Session-Id = "0e302c6745c5d68a"
Timestamp = 1173941460
