PIX 6 port forwarding
Feb 5th, 2007
I need to publish on internet my webmail server but I don't have any public IP address available.
My outside interface is assigned to a public ip address.
Is it possible to configure a port forwarding so that the request on a particular port on the outside address of the pix are forwarded to an internal address to a specific port?
Thank you for your support.
acle
Overall Rating: 3 (1 ratings)
daviddtran Mon, 02/05/2007 - 06:05
static (inside,outside) tcp inteface 80 web_server_IP 80 netmask 255.255.255.255
where web_server_IP is the actual IP address
of the webserver.
Keep in mind that port forwarding is the same
between version 6.x and 7.x
acleri Mon, 02/05/2007 - 06:29
Thanks david.
Considering that I have to publish an internal resource isn't the correct command static (outside,inside)?
acleri Mon, 02/05/2007 - 07:00
I enter the following command:
static (inside,outside) tcp interface 4100 webserver 443 netmask 255.255.255.255.
Now I need to configure the
access-list.
The source address should be any but the destination should be the webserver on port 443 or the outside interface on port 4100?
